Well, it’s wrapped in orange which denotes high voltage. High voltage can be AC or DC. What vehicle do you have? Which side and how far back is the connector? What PPoB if any do you have? By generator do you mean the PowerBoost traction motor, the high voltage DC-DC converter, or the alternator for non PowerBoost models?The plug is connected to the generator wiring harness but what do you plug into it ??? Is there some accessory that plugs into it????
If you have the Ecoboost 3.5, then your 2KW inverter only works when your engine is running. You dont have the PowerBoost engine which would require the Pedestrian Alert System.I got a tremor ecoboost 3.5 with PRO POWER ONBOARD - 2KW
I'm trying to find a cap for that harness but not having any luck with it, so tape it is!!I would tape it up good, along with that other exposed connector in the background. Better solution is finding matching connector to snap in a dead end but quality tape will do the job. Ford might be okay with dangling open connectors but I am not.
