Porpoise Hork
- #16
You can switch a bonded portable generator to unbonded this way. Most manufacturers provide instructions in the manual on how to do it. Now whether the PB can be converted in the same way remains to be seen as far as I know. One would likely need to pull the 110/220v inverter unit out and open it up to see how it's wired and if it is possible to convert it. Otherwise the best option to connect it to a house remains a 3 pole transfer switch.False: "The PB is BONDED and can NOT be unbonded." Ford doesn't want to take this on, but the simple answer is disconnecting one wire will unbond it. Note that unbonding it does not violate the NEC. Nor will operating it unbonded and connected to your house violate the NEC so long as your house is is properly wired. I've probed the system via my dealership and Ford just ignores the question. A real disappointment, Ford's better than this, they're just lazy.
