Porpoise Hork
Poking around on MicroAir's site https://www.microair.net/ looking to see if they had a 110v Easy Start unit designed for portable AC units and I find this nifty device..
Generator Bonding Plug
Makes me wonder if this simple $18.00 item would solve the circuit breaker trip floating/bonded neutral issue with the ProPower generator connection to houses without a 3 Pole Transfer switch...
Finally, a simple solution for a simple problem.
Sometimes your generator won’t start when plugged into the RV. When powering your trailer on a portable generator or low power inverter, certain surge protector devices like those on your generator will report an "OPEN GROUND" or “E2” or "OPEN NEUTRAL" fault. The equipment is looking for an earth-ground connection, grounding in a word. This can prevent your power source from starting.
To resolve this problem, all you need is Micro-Air’s Portable Generator and Inverter Bonding Plug. Truly plug-and-play, all it requires is for you to plug it into the outlet of your generator or inverter and then . . . walk away! It bonds the open ground and permits your power source to operate. No need for metal staking to ground your generator. This does the job [\QUOTE]
