rayray3
Greetings all,
Looking to splice into the incoming power of the 400 watt inverter underneath the rear passenger side under the small bench as I've seen done on this and another Ford forum. Wire looks to be 10 gauge which should be large enough for a 40-50 watt radio, but the fuse labeled for the inverter circuit (fuse #35) is labeled at 5 amps. I would need more than that fuse can cover, IF that is the fuse circuit.....
Reading another Ford forum, the member mentioned that they pulled that fuse but still had power going to the input side of the inverter. Looking at both fuse box schematics, I can't see where incoming power is being supplied from if this is the case.
Anyone happen to know which fuse this would be so I can see how large the fuse protecting the circuit is?
