TJSparky
You may want to see about them doing a valve break in learn procedure for the transmission. I had these same issues and once they did this it fixed it. I guess the procedure cycles the solenoids in the valve body extremely fast to remove any micro material that maybe causing slight valve sticking causing abrupt shifts. Seems to be a common issue with new trucks. The procedure is in FDRS, but the truck needs to be on a frame lift to do.
This may not fix your issue but might be an option to look into with the dealers.
