dolsen
I have for sale a powered steering column w/out active steering, the motor adjustment controls, wiring harness from steering column motors to a-pillar connectors, and and the powered steering column shroud. In my Lariat mid, all of the wires were populated from the DSM to the A-pillar connectors so I simply pinned them in there. Depending on your truck, you may have to run wiring all the way to the DSM. There is about 300 miles on this steering column, I bought it new
NOTE: Be advised, I DID cut the terminals off, I was limited on time and I, for some weird reason, have a very hard time depinning small terminals. I am about 85% certain there is still enough wire left to re-terminate and reconnect, but I will not make any promises, you may have to add length to the wiring. I will provide the correct terminals and my wiring diagram that I made specifically for this harness.
SOLD
As you can see, I did unintentionally overtighten them at one point, but it does not affect form, fit, function, or appreance.
SOLD
