erixgix
Lets hear your take on your powerboost’s power delivery characteristics and if you have observed any changes after the initial delivery.
Has her personality changed?
My before and after (consistent fuel source and grade):
I thought it was pretty punchy, relatively good throttle response at tip in even in normal mode, pleasantly hyperactive in Sport. The first couple hundred miles it seemed over eager under 45 mph, on the edge of unintentional wheel spin taking off in certain conditions under 15 mph. Transmission was learning, so produces imitate form shifts with occasional chirp on moderate throttle.
After 1,200 miles, it’s not the same beasty. Throttle response seems to have minor hesitation in normal. The eagerness is gone, taking much more deliberate throttle to get moving with any authority. Wheelspin is no longer a worry. Sport mode will help throttle response, but is also softer than before , missing that hyperactive feel. Transmission shifts are more prolonged. Full throttle is meet by an extended wind up time as it processes a kickdown, gets the 3.5 spinning faster, and then locks the torque converter for a lunge forward. Seemingly with less steam than it used to.
Staying in it finds full throttle shifts mushier. Could almost suspect some slip in the wet clutch pack to explain the feeling as well as it not seeing any wheelspin of a standing start with TC off in 2wd.
Thanks for any shares.
