Dale B
This is just one of the sources. The Ford sales literature also explains the process:Show me their documentation. I have seen other stuff, I'll go look for it... In the meantime showme.
https://www.autoblog.com/amp/2009/0...f-the-year-award-for-engine-block-coating-sy/
I am not concerned about the process. Mercedes has used a similar process since at least the mid 1980’s. It was used in their M119 and M113 aluminum V8’s and I am sure many others.
My point is that you won’t find cast iron in your oil analysis to tell you about your cylinder wear. There is no telling what is in the cylinder coating, so it will be difficult to figure out what is the cylinder wear component.
The exception is the 2.7, it has a cast iron block and cylinders.
