Rockman5159
same thing I didI just bought a couple Sylvania 194 LED bulbs and swapped them out. Around $7 each if I remember correctly.
i hope the leds run cooloer- the similar bulbs that a prior wner had put in my mercury interior lights, all damaged the housings from the resistors overheating- but they were not sylvanias...i just changed mine yesterday, bought the 168s as they were 0.5 watt, mot other ones on the rack were 1 watt... there were comments a few posts in worrying about flicker- LEDs only flicker on ac or pwm dimmed supplis- on DC they wont flicker at all, so no worries about camera viewing...I ordered bulbs from stage3motorsports and the swap is super quick and easy.
For me it was interesting how the plastic around the bulb appears to be some lower temp plastic as mine was burned black from the heat of the incandescent bulb. The LED will run way cooler and looks better...weird penny pinching move, but I get it. They are like most companies and would rather value engineer than raise prices - but instead they ended up having to do both.
