Tripdaddy95
I would like to read about how the PowerBoost really works. Maybe nerd out a little. Stuff like when and how it is actually using the electric motor or charging.
Yes! It comes with a free lunch.I would like to read about how the PowerBoost really works. Maybe nerd out a little. Stuff like when and how it is actually using the electric motor or charging.
thanks.Yes! It comes with a free lunch.
This is very limited but might get you started with component and function identification. https://www.fleet.ford.com/content/...owroom/resources/2021_F-150_ModifierGuide.pdf
If you do disable it, make sure you are covered legally. Federal law mandates the noise as a safety device for pedestrians. Should you disable it, and a pedestrian be injured or worse, a lawyer could rake you over the coals.thanks.
Loved the last line of page 1-2 or page page of the PDF. "Make sure the pedestrian alert sound system is not disabled". That annoying sound may or may not last very long.
Just hang your head out the window yelling "BEEP!! BEEP!! BEEP!!" when you backup around people.If you do disable it, make sure you are covered legally. Federal law mandates the noise as a safety device for pedestrians. Should you disable it, and a pedestrian be injured or worse, a lawyer could rake you over the coals.
Lots of misinformation regarding liability and the dump-truck-emulator. Removing that noise pollution neither opens one up to some magic liability, nor when connected some how provides an immunity shield.If you do disable it, make sure you are covered legally. Federal law mandates the noise as a safety device for pedestrians. Should you disable it, and a pedestrian be injured or worse, a lawyer could rake you over the coals.
