I noticed you're located in Michigan. Is it possible you drove/backed over a pile of solid snow and ripped it off?My brother pointed out that there was something hanging from under the engine, today. Turns out it's the under tray. I haven't seen anyone else post about it yet, but if you have one, check it out.
Truck is a '21 PowerBoost Lariat.
On RCI's website it says you don't have to remove the air dam on 2021 trucks.The RCI claims I need to remove my active aero-dam and I don't wanna.
Huh, ok.On RCI's website it says you don't have to remove the air dam on 2021 trucks.
https://rcimetalworks.com/https:/rcimetalworks.com/2015-2022-f-150-engine-skid-plate/
It says this under key features.
Huh, ok.
Thanks for this. The Stage3 website says it DOES require.
https://www.stage3motorsports.com/f150-15-engine-15-22-f150-4wd-rci-engine-skid-plate-kit.html
'Air Dam Removal Required RCI's skid plates require removal of the factory air dam for installation.'
I have that same POS material under my Lariat. I'm disappointed Ford didn't make it out of hard plastic like some floor mats. C'mon - I bought my truck, paid over $70k for it (I know some Gen14 owners paid a lot more than me) and darn it, we deserve better. Maybe we'll luck out and Ford will issue a TSB on this and provide us with something better. If not, I'll be buying the stuff from RCI. I'm sorry for the rant and thank you for the info..I noticed you're located in Michigan. Is it possible you drove/backed over a pile of solid snow and ripped it off?
Are these things under all of our trucks? My current truck and each before that never had anything like this. I vaguely recall asking the dealer about it in 2018 and he called it a diaper I think and said they just got rid of them after the first oil change. Probably why my 2018 left a blackspot on the garage floor from a weep hole in the exhaust or something.I have that same POS material under my Lariat. I'm disappointed they could make it of hard plastic like some floor mats. C'mon - I bought my truck, paid over $70k for it, and I'm sure some Gen14 owners paid a lot than me. We deserve better. Maybe we'll luck out and Ford will issue a TSB on this and provide us with something better. If not, I'll be buying the stuff from RCI. I'm sorry for the rant and thank you for the info..
Here is my thread on getting the Powerboost transmission skid plate. https://www.f150gen14.com/forum/threads/pb-aluminum-transmission-skid-plate.8140/#post-156559FWIW this has been an issue since the 12th gen trucks (~09+). I'd say about 1/3 F-150s you see here on the road has that part hanging down dragging on the ground; pretty embarrassing. It was ripped off of my dad's 2014 and my sister's 2017, and only a matter of time before it falls off of our 21's. When it does I'll look into replacing with an aluminum skid... just wish someone would come out with a trans-skid for the powerboost already.
