I want to be able to essentially turn the copilot 360 (non bluecruise) system into hands free by using a device to fool whatever sensor is used to monitor steering torque input (this would also work on blue cruise equipped vehicles outside of "mapped" areas) . As those of you who use the system know, far too often it requires you to move the wheel when it's not even required 'just cuz' -- even worse you can be using buttons on the steering wheel and the dumb system still requires torque input. I mean, if you're using buttons on the steering wheel, clearly your hands ARE ON IT ALREADY!? I'd prefer to stop having to move the steering wheel while in a straight stretch of road because incompetent programming/ers deemed it a good idea.
I've got quite a few projects going on already but figured I'd start getting community input as perhaps someone here is already familiar with the intricacies of the system. In my 'daydream' it's as simple as adding a little bit of voltage to the sensor at short random intervals to fool it into believing there's torque on the steering wheel (though I'm guessing it's a PWM signal). It'd be even sweeter if it could include a dial that could be added to adjust the level of power steering assist as well. There's no reason for the required steering force to ramp up as much as it does at speed. Fighting the steering wheel is a big contributor to driver fatigue.
