Does anyone have a dash camera mounted with a ball mount ?
I've been thinking about installing the Builtright Dash Mount for when we are towing since we currently have multiple items suctioned to the glass currently. I also want to switch the trailer TPMS from this Tymate one that doesn't mount to anything to a ballmount compatible model like the Tire Minder one.
If I go through the process to convert these three items to ball mounts, then it would be easy to add a fourth ball for a dash cam. So far, I'm only seeing Go Pros mounted with ball mounts and possibly the Garmin could be, but its mount is on the top. Can the Garmin image be inverted to be mounted upside down ? If not, I would have to use some crazy crane looking contraption using a double ball and two arms.
This is the setup I use. It works great and is all plug and play. You can barely see it from the drivers seat.
Vantrue N2S 4K Dash Cam with GPS, Front and Inside Dual 2.5K 1440P Dash Camera with GPS, IR Night Vision Uber Car Camera, 24/7 Recording Parking Mode, Motion Detection, 256GB Supported https://a.co/d/cOmlzRr
Dongar Technologies Dash Cam Power Adapter 16-pin for Select Ford Vehicles https://a.co/d/6HjbZ9q
Vantrue N4, N2S, X4S, N1 Pro(2023), T3 Dash Cam GPS Receiver Module Type C USB Port Adhesive Mount for Windows and Mac https://a.co/d/ahltFfm
