Rubbergoose
Quick background. 2021 F150. I bought the truck wrecked so I had to take the console out to remove the air bag module. Also did the 8"-12" radio conversion through infotainment which replaced the APIM.
The truck is done but I do not have any power to all 3 usb outlets on the center console, or the center console light. Can't remember the exact fuse numbers but fuses 30-35ish are good. I replaced the first usb outlet, thinking it was bad, but the new one didn't work either. I put the old APIM back in, outlet still doesn't work. I plugged an old phone without a battery into the cord that supplies the first outlet, and it turned the phone on. I saw where someone said to do a soft reset of the radio, still didn't work. The led rings aren't even lighting up.
Am I missing something? It there a Forscan code to check?
