80A circuit question
Pilot2022
Jul 26, 2021
165
108
PNW
I was planning to install a 50A circuit to install standby generator in cases of power failure. With ford's 80A circuit potentially being able to power the house, I am thinking of just using one circuit that can power the house either from the truck or the generator.
Typically, a generator feeds a breaker that has to be turned on with an interlock kit. How does the backfeed of Ford's 80A circuit work? Is it going into some automated transfer switch which will automatically switch to the 80A for power if utility cuts out?
Since exact date of truck is TBD, should I just run the 80A circuit to connect with the generator for now (it might be an overkill)...
sotek2345
Tom
Jun 7, 2021
29
3,542
4,091
Upstate NY
Engineering Manager
We haven't gotten any details on how the whole home power backup will work. We know you need the 80A EVSE from Ford (which is a 100A circuit), as well as some other equipment - definitely a transfer switch and potentially an inverter as well.
I am in a similar situation in that I need to get an EVSE installed now as my wife has a Mach-e or order with a build date in late October. My plan is to run a 100A circuit to the location for now and just install a lower power unit as a placeholder until I get my Lightning. Some rework will be needed, but at least the wiring run won't have to be redone.
adoublee
Aug 30, 2021
714
630
Midwest
2 EVs
Keep in mind that if you ever expect the truck discharge into the the utility grid for time of use savings or demand charge savings on your electric bill, the utility will probably require the circuit go through a exterior disconnect switch they can access and visually verify the position of. This will not be a truck feature day 1 but they are talking about it for the future. Also hard to plan for, but you might consider when routing the 100A circuit.
Pilot2022
Jul 26, 2021
165
108
PNW
Thanks. I think for now I will ask electrician to run a 100A circuit to the garage and will hook up the generator to it. Will make changes when/if Lightning gets delivered...
Brian Head Yankee
May 20, 2021
276
339
Brian Head, UT
Bronco Sport, Chevy Colorado 4x4
Good plan. You can always feed 50 amps thru 100 amp wires but you can't feed 100 amps thru 50 amp wires.
Pilot2022
Jul 26, 2021
165
108
PNW
By the way, are EV chargers universal like regular battery chargers or are there any main differences that one needs to consider?
shutterbug
Joseph
May 20, 2021
1,183
1,147
Phoenix
Most are the same, except how much power they deliver and whether they are "smart" or not. If you're going to have multiple EVs, you may look into ones that can share the circuit.
Pilot2022
Jul 26, 2021
165
108
PNW
Good call. I can see that being the norm in many homes. After the latest run-up in stock and real estate markets, some homes in our neighborhood have competed switched over to the EVs. Too many look alike cars :)
sotek2345
Tom
Jun 7, 2021
29
3,542
4,091
Upstate NY
Engineering Manager
Since my wife is getting an EV as well (Mach-e), I considered a dual EVSE but I don't want to give up the home power backup from the Lightning. I just made sure we will both have enough range to charge every other day comfortably so we can trade.
metroshot
Pat
Aug 26, 2021
93
2,098
1,707
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
Since details on the Ford 80A charger & home circuit connection is up in the air, and the wait times for the special installer may take awhile, I currently use a L2 (240V 20A) J1772 EVSE charger for my Honda Clarity, does anyone know how long the charge time will take for the standard range F150 Lightning ??
shutterbug
Joseph
May 20, 2021
1,183
1,147
Phoenix
Since Ford said that it's 32A mobile charger will give you 14 mile per hour of charging, my guess is that 20A charger will give about 9 miles per hour.
pstansel
Paul
Sep 13, 2021
317
297
Tolland, CT
F150 Lightning Lariat ER, Hyundai EV6
Very curious about this as well in reverse. Curious if the F150 could power through a standard generator hookup for a portable generator which my house already has.
SteffanG
Steffan
Jun 14, 2021
320
264
Langley, BC
2011 Audi Q5 (written off), 2008 F150 XLT HDPP
Electrician
Don't see why you couldn't use a hookup like that. It wouldn't be through the back-up power function though (that requires a likely expensive inverter) and would be through using the 30A locking receptacle in the bed of the truck which requires you to manually connect the wire and limits it to 7.2kW max.
With the generator hookup on the house, make sure it is a male plug on the wall as a double male extension cord is extremely dangerous and goes against every electrical code. Said plug should also be through a manual transfer switch that cuts power from the main breaker as well (manually turning off the main breaker is against electrical code, though many people do it). Without the manual transfer switch, you are risking the lives of any linesman that could be working on the line should you forget to turn off the main breaker.
pstansel
Paul
Sep 13, 2021
317
297
Tolland, CT
Yeah no suicide cord here, and it's a manual transfer switch already. Properly wired to code. Thanks I was overlooking the 30A, that will meet my needs nicely.
