Pelicanman
Has anyone experienced water coming in from the speaker in the headliner with b&o. Roof is definitely closed. Not sure if anyone has experienced this and or got it fixed yet?
What are these images from?Sounds like a plugged up drain tube or one of the drain tubes are not connected to the sunroof.
I believe this was a problem on the 13th gen as well, so that's where I'd start. Drain tubes are shown in yellow, one at each corner of the pano-roof.
Ford’s service info.What are these images from?
I would have died if you woulda went for the bit and just said "oh, I decided to whip up some cad drawings for you of where I imagine they might put drain tubes" or something.Ford’s service info.
Thank you, I will have them start there. Only happened oncSounds like a plugged up drain tube or one of the drain tubes are not connected to the sunroof.
Yes I do have the dual panel roof, and B&O unleashed. Headliner doesn’t feel wet however water is definitely coming out of the drivers side speaker in the headliner.The B&O unleashed? Do you have the dual panel moonroof? Like others are saying a good place to start is the drain tubes for the moonroof.
The speaker in the headliner is what I was thinking. Sorry, man hopefully Ford can get it fixed up for you.Thank you, I will have them start there. Only happened onc
Hi Jim, my truck is there now because of rain coming in all weekend. Hopefully by early next week I will have it back.Tim, did you get the water leak fixed - what did they find - if it's fixed?
