Buyer2021
So, just for grins, building on the post by @SALEEN961, I looked at the connector diagrams to find the wire gauges used on these inverter power circuits in the 2022 model year 400W inverter implementation:
Using standard calculators for ~12VDC and ~120VAC wire ampacity with some assumed lengths of runs tells me that all of those wires are sized only for the input & output amps of a 400W inverter with no 'excess ampacity'.
IOW, IF one wanted to remove the OE 400W inverter and install even a minimally higher-output inverter in its place, ALL of input (~12VDC power to the inverter) and output (~120VAC power from the inverter to the outlets) wiring would need to be upgraded.
Yeah, that could be done but it'd be a big wiring PITA, IMO.
As I already learned it's dangerous to assume anything, but IMO it's likely the same would hold true for the 2021 model year implementation (I don't have a source to check the 2021 wire gauges).
Bottom line - if ya want more than 400W / ~3.3A of 120VAC out of an inverter your (IMO) 'sensible solution' is to leave the OE 400W system in place and go with a totally separate / redundant higher-output inverter system of your choice, either 'clip-on' or 'hard wired'.
