YesI’m not sure there is enough info to answer your question, or I’m just dense. What do you mean by “
upgrading your XLT to “full spec”? Do you mean upgrading the seats and trim to platinum or limited level?
Did you add 4A to yours?I took my XL STX to the equivalent of a 502 A Lariat
Mine has Blue Cruise, APA, Power Running Boards.. Multi Contour Seats.
I added everything. It was a base Truck. I have heated and cooled seats.
As far as cost.. that is something with MANY variables. No real answer for that but its in the 10 thousand dollar range Id bet if you go full tilt.
I haven’t gone to the 4A portrait. I went from the 8” to 12” sync 4Did you add 4A to yours?
I'm not familiar with what "4A portrait" means so excuse my ignorance. I was referring to the automatic 4x4 that Lariats and upper trims come with.I haven’t gone to the 4A portrait. I went from the 8” to 12” sync 4
I thought about going to the portrait but decided against it at this point
4A is what is in the Mach E and LightningI'm not familiar with what "4A portrait" means so excuse my ignorance. I was referring to the automatic 4x4 that Lariats and upper trims come with.
What is your level of knowledge and comfort with electrical systems, wiring, and making your own harnesses, not to mention tearing apart the inside of your dash and interior to make the upgrades? It’s all possible, but it’s not cheap or easyYes
seats, systems, touchscreens....etc
(same features as the Limited trim)
