Graygoose2021
- Nov 18, 2021
- 31
- 1,892
- 1,801
- Central US!
- 2021 F150
- Sales
ahhh...you did the DD heads?
Nope still running the AlphaRex Luxx, just switched to white drls, can’t get myself to pull the trigger on heads. I’m waiting to see the morimoto’s on yours! I just installed the dd fog pocket kit, will have a write up in the coming days!ahhh...you did the DD heads?
No, the the selective yellow pods I had sitting around so they were the generation before backlight, and then for the pro whites I didn’t want to have to mess with more wiring. Even though I already ran a drl wire for my headlights(oversight). If the whites had backlight in the center it would look amazing. I was just trying to keep it simple!Those look so good. I wasn't sure what direction to go (have OEM LED quads/LED fogs) but I am definitely leaning towards these for the fogs and maybe swapping in BAP headlights, rather than the full DD Elite headlight/fog setup. The yellow fog/white pro driving light combo seems perfect (I'd probably have the whites on a separate switch).
Have you wired up the backlight for when they are off?
No, not at all, but I only have 2073 miles now. I know you're in TX too, but I know we haven't put down any "brine" on the Austin area roads to fester something like that......Is the middle of y’all’s rotor/hub rusty like this? I sanded with steel wool and the put an anti rusting lubricant on it to try and prevent future surface rust. Just wondering.
Adams eco all purpose cleaner and an assortment of brushes. I then hit all the plastics and wire looms with silk shine dressing. If your engine bay is really bad I would use simple green or something similar. My engine bay was just dusty with a little mud low!what did you use to clean your engine bay?
Thanks fella. I like your build so far. Is your front license plate holder mounted offset or center. Ive seen pics of both?Adams eco all purpose cleaner and an assortment of brushes. I then hit all the plastics and wire looms with silk shine dressing. If your engine bay is really bad I would use simple green or something similar. My engine bay was just dusty with a little mud low!
