jvbronco
2021 5.0 with 11k miles. Noticed what I thought was an oil stain in my garage and noticed that there appears to be oily water / watery oil liquid dripping from several points between the engine and exhaust tip. Dealer says it is soot in the exhaust condensate. This happens on startup, when the engine is idling high - the water splashes and drips.
Took the truck in and dealership claimed this was normal operation - service tech and service manager both had a "canned" spiel about how the turbo system in the ecoboost can cause this... I had to kindly remind both that this was NOT the ecoboost and was the V8.
After some discussion with Ford customer service (800#) and the service manager at the dealer, the dealer changed the diagnosis to "not normal, but no solution known" status (I opened a "case" with Ford, with case #). This was supposed to trigger additional support from Ford on the issue, but I'm getting vague updates only after multiple emails/ phone calls to the service manager which mostly consist of "nothing yet, hoping to hear back from XYZ department at Ford". Honestly feels like the service manager isn't actually doing anything and just sending me BS responses or only following up with Ford once I've sent an email /left voicemail.
They've recommended not driving the truck less than 20km per cycle, using premium fuel, and not idling more than 10 minutes.
Any recommendations on what might be causing this or what I can do to escalate so that I can get some actual support?
I'm loving my F150 but disappointed that my nearly brand new truck is leaving black stains wherever I start the truck.
- I already use premium (I'm a sucker, and I came from the 6.2 V8 from GM, which requires premium so I was already used to it)
- I do not idle more than it takes me to walk to the truck, get in, buckle up, and go
- I am not going to drive a minimum of 20km every time I get in my truck - that's dumb
