Ok, I took the hose off and was able to blow through it. Here is what the port looks like on the inside. Normal?That is the pcv valve. It recirculates crankcase vapors into the intake manifold. It's probably blocked. Pop it out and you should be able to blow through it, in one direction. If you can't, it's plugged with tar. Get a new one and pop it in.
