Need some help!!!
Jackson84
Justin
May 31, 2021
Louisiana
2021 F150 XLT 4x4 with Max Tow
U.S. Army Active Duty Critical Care Flight Paramedic
Was camping last week with the family and plugged a shop vac into the truck to vacuum some sand out of the truck and camper from the beach. I only have the 2KW power receptacle but thought it could manage the shop vac. It ran for about 10 second and turned off. The kiddo un-plugged it, plugged it back in and it turned off again after a few seconds. Now the 400w 120v plug in the cab and the bed both illuminate the indicator light for about 3-5 seconds and then go out. My daughter tried to charge her laptop the other day on a trip (she has done many times before) with no success. Manual shows fuse 35. Fuse is still good. However it’s only a 5 amp. Swapped it with fuse 30 that day it runs nothing lol and did the same thing. Any info or suggestions would be helpful, my dealer where I’m at is terrible and the service department is even worse. Thanks in advance.
RedTXV
Apr 16, 2021
669
542
Houston, TX
2021 SQ Limited
I’m going to assume you reset the gen? Or hit the trip switch in the bed?
Jackson84
Jackson84
Justin
May 31, 2021
Louisiana
It’s the 2KW on an XLT, no generator just that small inverter under the rear seat. I would assume there is a way to reset it. The fuse block is just converting the DC-AC power and those fuses are good but it won’t stay running. There isn’t a breaker reset button on the XLT for the 2KW.
RedTXV
Apr 16, 2021
669
542
Houston, TX
2021 SQ Limited
Same 2kw system here. Have you gone through the sync screen to reset it? I’ve had issues where mine was completely turn off.
Could have sworn I had a reset button in the bed, but it’s just a power button.
Jackson84
Jackson84
Justin
May 31, 2021
Louisiana
I haven’t found anywhere on the entertainment screen to turn it on or off or reset it
Jackson84
Jackson84
Justin
May 31, 2021
Louisiana
Ford F-150 Need some help!!! 040D5168-D939-4F11-8C2E-1CDC25C5F581
Mine says fuse 35
Gros Ventre
Nov 13, 2021
1,650
1,133
Western Wyoming
Powerboost
Put in a new fuse... I have seen fuses that appeared good still not conduct... rare but it happens...
Jackson84
Jackson84
Justin
May 31, 2021
Louisiana
I did, same result, light above each outlet illuminates fort a few seconds they goes out and acts like neither plug has power to it
