MY22 Adding SiriusXM
Ranual
Randy
Feb 13, 2023
90
Chicago, IL
2022 Ford F150 XLT
IT Consultant
Now I need to make my Nav and cards work, if y one can chime in. I changed this line to match my brothers as well no luc
7D0-01-040004880060C8
Previously I had 02E4 8800 60AA
The first two digits in the first hextet should be 02 as this is what tells the APIM that NAV is enabled.
From forscan spredsheet. Note: they left out the leading zero on the spreadsheet
Ford F-150 MY22 Adding SiriusXM 1682118327891
The second hextet is fine at 8800
The first two digits of the third hextet are good. The last two digits are the check digits so you will get an error in Forscan stating this. I have a checksum calculator somewhere. I'll need to look for it.
You may also need to change 7D0-02-02 to tell the APIM that the GPS from the TCU is not present.
My register is set to 4200 00D8 00F5
Ford F-150 MY22 Adding SiriusXM 1682119029846
You should have the NAV card on your screen, but No GPS will be displayed if you have the APIM set to get the GPS from the TCU.
I hope this helps.
Ford F-150 MY22 Adding SiriusXM 1682118258073
XLT22
Nov 12, 2022
245
159
GA
2022 302a XLT
If you plan on actually trying to navigate, I suggest you look at 7D0-05-01, 4th digit 1st column.
pelon222
Lupe
Feb 18, 2023
64
Tucson
2022 F150 RCSB
Engineering
This is what I have now still no Nav on the screen. I got a checksum error when I changed it to this on 7D0-01-04. Sorry for the bad pic hopefully someone can point me in the right direction
thanks for your help
pelon222
Lupe
Feb 18, 2023
64
Tucson
2022 F150 RCSB
Engineering
Ford F-150 MY22 Adding SiriusXM IMG_3311
XLT22
Nov 12, 2022
245
159
GA
2022 302a XLT
You have swapped in a navigation APIM haven’t you? What was it out of?
pelon222
Lupe
Feb 18, 2023
64
Tucson
2022 F150 RCSB
Engineering
Yes, sorry should’ve stated that first. My truck is an 22 XL single cab, did the 12” screen and what I think is a Nav apim not sure what the apim came out of. I also did the 12” cluster and ACM.
dhageremtp
D
Feb 14, 2022
202
165
North Dakota
2022 F150 Lariat
Healthcare
I still don’t know what the splitter I bought is for.
The splitter is only needed if you change the APIM to nav and add back XM,. it connects behind the glove box and splits the antenna signal to both of those. if you didnt do nav you dont need it.
Musclez
Marco
Apr 7, 2023
113
NJ
F150 14th Gen
got it. Thanks. Do you think you need to leave the other antenna in the headliner as OP suggested?
dhageremtp
D
Feb 14, 2022
202
165
North Dakota
2022 F150 Lariat
Healthcare
It will avoid the tcu Dtc I did not do it. FordPass works just fine.
XLT22
Nov 12, 2022
245
159
GA
2022 302a XLT
Okay well that’s an important bit to know. As has been stated many times on this site you can’t just throw this stuff together like on the previous gen trucks.
Musclez
Marco
Apr 7, 2023
113
NJ
F150 14th Gen
Yes you need a female to female connection from the ACM to glove box. I would think you could get by with someone about 12" at minimum. What you show in the photos is plenty long enough.
In regards to that splitter, does that just instal to the ACM then to the glove box?
also regarding TCU issues withoriginal antenna what’s the correct oem way to replace? I don’t see any other antenna options from ford parts.
If I have the Sirius and factory cell antenna now installed why would the tcu throw a code since there are only 2 OEM options for Right side roof antenna?
Musclez
Marco
Apr 7, 2023
113
NJ
F150 14th Gen
I keep pulling this data from the OEM Ford as bill decoder because that works for me. Is Vin I pulled with the screenshot below is from a XLT with navigation. Try the bottom below hex code. See if that works.
Ford F-150 MY22 Adding SiriusXM D5A72C26-9659-4B2F-9AB7-350E00944F0C
XLT22
Nov 12, 2022
245
159
GA
2022 302a XLT
Yes.
The "correct" way is outlined in the first post along with an alternate method. In non-nav trucks, the TCU receives location data directly from the antenna. On nav equipped trucks it routes through the APIM.
pelon222
Lupe
Feb 18, 2023
64
Tucson
2022 F150 RCSB
Engineering
thank you, I’ll give that a try tomorrow
Musclez
Marco
Apr 7, 2023
113
NJ
F150 14th Gen
So this is the connector under the glove box, Ive tried to take this apart, anyone have insights on this connector?
Ford F-150 MY22 Adding SiriusXM image
