Lower plastic grille
SpaceWhiteF150
Sep 18, 2021
59
1,867
972
Montgomery, Texas
I have a 5.0 truck which has the lower grille fully blocked off. Do y’all know where I could buy the one from a 3.5 eco truck?
Ford F-150 Lower plastic grille 26F58D5B-1714-4DA9-AEED-52AB691B8490
powerboatr
Robert
May 9, 2022
134
3,100
3,491
North East Texas, Piney Woods
2022 F150 King Ranch 4x4
Retired Navy Senior Chief
SpaceWhiteF150
SpaceWhiteF150
Sep 18, 2021
59
1,867
972
Montgomery, Texas
Do y’all think I could just order that piece and replace what I currently have?
SpaceWhiteF150
SpaceWhiteF150
Sep 18, 2021
59
1,867
972
Montgomery, Texas
Is it the same piece from 18-20 bumpers also? Thanks
jaggah
Joban
Mar 14, 2022
167
95
Brampton
22 F150 Powerboost
What license plate mount is that
SpaceWhiteF150
SpaceWhiteF150
Sep 18, 2021
59
1,867
972
Montgomery, Texas
It is the lower grille for eco boost trucks and truck with block heaters.
Andyc
Andrew
Dec 17, 2020
97
111
Sussex UK
14 Shelby Raptor. 05 AEV Jeep TJ4.6 SC. 21 Lariat
Business owner
Andyc
Andrew
Dec 17, 2020
97
111
Sussex UK
Business owner
It all unbolts/ unclips. The solid infill and open slots have the same fittings so are interchangeable
Ford F-150 Lower plastic grille 1659122059951
SpaceWhiteF150
SpaceWhiteF150
Sep 18, 2021
59
1,867
972
Montgomery, Texas
Did you successfully do the swap? If so do you have to take the bumper off? Thanks
22XLT
Oct 7, 2021
125
80
IL
22 F150 XLT
I have the snowplow prep on my 5.0 and I have just a big hole less where the license plate bracket is mounted.
Does your front bumper have a solid plate because your vehicle is equipped with the active air dam that snow plow prep vehicles do not come with?
Guessing maybe it plays a role in the efficiency it’s supposed to create?
SpaceWhiteF150
SpaceWhiteF150
Sep 18, 2021
59
1,867
972
Montgomery, Texas
Snow plow and block heater trucks get the ones with openings. I’m trying to move my plate to one side and make room for led pods or a light bar!
Andyc
Andrew
Dec 17, 2020
97
111
Sussex UK
Business owner
Took my bumper apart for other reasons. Did not do swap but the solid infill panel is identical fittings. Can be done with bumper in place. The small plastic panels either side will need taking off first and then the center. Easier and less chance of damage to paintwork if can be pushed from pinching clips with pliers from behind. 7 clips 3 either side as in picture and one centre bottom. Alternatively with decent quality panel removal tool (can be done with screwdriver but more likely to damage paint/plastic) between bumper and panels from outside.
Ford F-150 Lower plastic grille 1659160932678
Andyc
Andrew
Dec 17, 2020
97
111
Sussex UK
Business owner
Update: Slightly more involved as have to remove the 4 white plastic clips that attach the bottom valance to the front, once these have been removed the full front plastic part can be unclipped by pulling forward together with center section. The center plastic will then unclip and can be r replaced with solid infill. All easier done with bumper removed, but can be done in situ accessing clips on V8 from underneath. Not sure if access is compromised with the intercooler on other engines.
