Load Range E Tire Pressure
smarty39
Kyle
Aug 23, 2021
64
50
Alberta, Canada
2021 F150 Velocity Blue Lariat Sport
Wondering what psi everyone is running in their load range E tires? I currently have K02’s that are rated at 80psi max cold and I am running them at 50psi when unloaded. Is this good/bad/personal taste?
Dealership had them at 40psi when they installed the tires at delivery but I felt like that was really low for an 80psi max cold rating.
PBXL
Oct 11, 2021
107
179
California
2021 F150 XL Powerboost
Half the people on the internet say run them at 35 psi like it says in the door, and half say run it at 50 psi so I split the difference and run mine at 45 psi cold.
ocwill1
Owen
Jun 2, 2021
47
33
MD
2021 F150 Powerboost 502A, 2021 Lexus RX350(wifey)
Computer System Engineer
295/60/20 Pro Comp A/T's at 40 all around.
TJSparky
Oct 18, 2021
501
439
WA
I was always told use normal 40 psi for everyday use but if your going to max load or towing use 80 psi cold on load E range tires
ocwill1
Owen
Jun 2, 2021
47
33
MD
I don't go to 80 when hauling heavy, I go to about 60 on tires, and put air bags to about 60 as well. Did it when hauling 1 ton of pellets for pellet stove and it worked well. kept it level. Tires I believe can handle 3500ish pounds at 80psi...
Pedaldude
1,371
1,994
The 4Runner I drive occasionally has K02 tires and I bel that they are the E rated ones.
The rating is less for the higher payload as it is for a tougher sidewall that can better resist rocks and debris while off-roading.
A higher rated tire won't help with your axle strength, so stick with rated payload.
Some of the LT truck tires have sidewalls like birthday balloons and many have found it out the hard way, myself included. Though they can get better MPG.
I run the door PSI and sometimes a little higher but a chalk test can tell you how your contact patch is at different PSI.
UGADawg96
Feb 28, 2021
2,736
4,559
JAX, FL
'21 302A 157 PB
When Discount Tire installed LT285/60r20, they put them at 45psi cold and they feel the same as the stock Hankooks did when at 35psi when commuting or regular driving. When I recently towed at full capacity, they didn't look like they had any additional weight on them at that same pressure. I was temped to add some air when towing, but the load charts here: https://tirepressure.com/lt285-60r20-tire-pressure (this site could be outdated) show that at 45psi they can handle up to 4800lbs which is well over the axle load limits for this truck.
Atlee
Erroll
Sep 14, 2021
1,122
1,126
Mechanicsville, Virginia
How much of a hit to your miles per gallon did you take when the LT tires were put on the truck?
UGADawg96
Feb 28, 2021
2,736
4,559
JAX, FL
'21 302A 157 PB
I really haven't noticed any. Maaaaybe 1 mpg. Hard to tell to be honest. With the OEM tires, GPS said the speedo was off. With these tires, the speedo now matches GPS.
blue2766
Julie
Apr 30, 2021
Indiana
2021 Ford F150
Supervisor
My
295/60/20
My 295/60/20 ridge grapplers are at 35 psi and have a really rough ride, how is yours at45 psi?
wayfarer556
Feb 26, 2021
358
711
Austin, TX
2021 F150 XLT Powerboost 302A
I run Michelin Defender LTX M/S (275 /70 R18) E rated tires on my truck. I've experimented a lot with pressure, and have found 40 to be the sweet spot when I'm not towing. Much more than 40, the drive becomes very unpleasant...I can feel literally every rock on the road. Less than 40, the ride feels mushy.
When towing, I put them to 50 PSI. Works great.
Suga Sean
Sep 21, 2021
Nola
personally I find the the higher the load range the tire is the more air pressure I have to run.
