Heated Steering Wheel Retrofit - updated with information
rikkiranger98
Corey
Jan 9, 2023
Pittsburgh Pennsylvania
2021 XLT Powerboost
It is
the only reason I did it is because my apim software is too old to do the climate bar.
The easiest way to get it is to open the apim simple programming (the one that doesn’t say as built) and under vehicle type, select “f-series” I believe it was. Someone said select “super duty” but I didn’t see that option. Make sure you reset apim after sending changes.
Awesome, i believe i am in the same scenario with my software. I like the look and that it doesn't show the cooled seat option since i do not have them nor intend to install them. Your screen is definitely the option that i would like to go with.
dolsen
Aug 19, 2022
2,078
1,898
KY
2022 Rapid Red 701A
deejay9556
Sep 7, 2021
39
WI
2023 F150
When you're looking make sure you see 4 pins in here:
and 2 in here:
EDITED for clarity: this assembly is NOT HSW compatible, so there are no pins
I appreciate the info, that really helps. The search continues...
dolsen
Aug 19, 2022
2,078
1,898
KY
2022 Rapid Red 701A
I already have one but have been searching ebay to see if I can help others find one. I have SCOURED ebay looking for one and have come up empty handed. I am not saying there are none, but I believe it'll be hard to find the one or two that may be on there.
I will also continue looking and will post whatever I find on this thread. Also note that the trucks with active steering require a different clockspring assembly
JScaro
Nov 4, 2021
309
322
Georgia
2021 Ford F150 Lariat 501.5A
Beer Drinker
They have them here at Boosted GreyGoose Designs but there pricey. He does provide the proper clock spring, harness to go to the BCM and instructions on how to install. Makes it nice and easy. I have one coming. I also ordered a clock spring from my local Ford dealer - they said 2 weeks, we'll see.
Kevin7898
49
Nanaimo, BC
2021 f150 xlt
i went the boostedgreygoose route for mine, easy enough install. comes on with my remote start for now till i source a new hvac panel or update my apim.
Ford F-150 Heated Steering Wheel Retrofit - updated with information 324264068_1301042027292153_5603060210866995352_n
Ford F-150 Heated Steering Wheel Retrofit - updated with information 324331883_707198777683123_8691756995490421314_n
Gallagher023
Dec 10, 2022
New Jersey
F-150 LARIAT 501A
This may be a dumb question but I have a 2022 501A Lariat I checked my BCM connector and port 15 is empty obviously but my question is when I run the power wire into it do I just run it unsheathed into port 15 will a plastic tab grab the wire? Or is there a metal pin that can fit in there that I can attach to the wire to properly click into the BCM connector like the other wires or is just sticking the unsheathed wire into the port work ?
EDIT see a post from an older F150 heated steering wheel install from boostedgrey this is the pin Im talking about.
Ford F-150 Heated Steering Wheel Retrofit - updated with information Screenshot 2023-01-12 231950
Thanks!
Also has anyone been able to find the clock spring instock at all anywhere every place that Ive ordered it from is delayed into march!
JScaro
Nov 4, 2021
309
322
Georgia
Beer Drinker
Thanks!
@Gallagher023
Easiest way for you would be
Order the clock spring an harness from Boosted GreyGoose Designs It's $351.96 but will include instructions and the needed wiring harness for Plug & Play
Than order these parts from Online Ford Parts
It includes the Rain Sensor if you want / need it.
Ford F-150 Heated Steering Wheel Retrofit - updated with information 1673624762055
Dimi_5.0
Dimi
Sep 12, 2022
Frederick MD
2021 Ford F-150 Lariat
Received all the parts to tackle my '21 Lariat 500a. Ordered the HVAC control module ML3Z-19980-K from Tasca parts before Christmas and it is indeed the one with the temp readouts in the knobs.
Ford F-150 Heated Steering Wheel Retrofit - updated with information 20230112_212848
Gallagher023
Dec 10, 2022
New Jersey
F-150 LARIAT 501A
When did you order your clockspring? Do you know a site that has it instock?
Dimi_5.0
Dimi
Sep 12, 2022
Frederick MD
I got lucky on the clock spring and found a new open box one on eBay with the stalk for $120.
xlover
Nov 21, 2022
Boston
2023 Raptor 37
This makes sense based on what I have sitting and waiting (ordered a few months back in anticipation of this, now just need my built truck to ship). I have ML3Z-14A664-B, and will swap the stalk and the power steering wheel adjustment over.
Quick question does ML3Z-14A664-B have the SCCM module attached at the rear? I realized this part might literally be ONLY the clock spring not the controller as well. Which would mean nowhere to plug the power harness from the vehicle into.
superfordman
Troy
Jun 29, 2021
803
770
NE CO
2023 F150 Lariat 501A
Precision Ag Guru
Lucky, I ordered mine 12/20/22 and Tasca just cancelled my order for it saying can't get it now...
Dimi_5.0
Dimi
Sep 12, 2022
Frederick MD
Might be your lucky day as I
ordered two.....one part number from Tasca and another part number through another vendor and expecting to receive the second one next week. If it the second one is the same you can buy it from me if you are still looking.
Buddy726
Joe
Mar 6, 2022
97
28
United state
2022 f150
Who knows the right version of forscan for the 23’s to down load. And the procedure to programming a new hvac to work with the heated steering wheel? I have a brand new hvac. And clock spring (coming) want to program everything so they work properly. Thanks.
