motivology
Need your expertise and experience regarding if I should do a leveling kit or a lift kit. For a lift, I cannot do higher than 4” due to 7’ garage height clearance. For now, I’m not considering pucks.
I do occasional towing of car/truck & heavy loads. Will be towing boats down the road as well.
Here’s the trick - I have a ’21 F150 Platinum equipped with 3.0L Powerstroke diesel engine, 4WD and 6.5’ bed. It’s near impossible to find a leveling or lift kit that will work with diesel engines. Based on my research, ICON seems to be the only choice.
First question is, which is best for occasional towing - leveling or lifting it?
Second question is, would you do coilovers all around - or would you do coils front and have a different set up in the rear for occasional towing?
Originally I was going to do a complete kit all around but with occasional towing, I am not sure which is better.
Lastly, I am not sure which ICON stage kit would be ideal either so I’d like your advice on that.
This is my first time leveling / lifting a truck and these kits are not cheap so I want to do it right the first time. I will be keeping this truck for a long time. Ride quality and long-term reliability are important.
After that’s done, I will be looking to have 33”/34”/35” AT tires on a 18” or 20” wheels. I do not want any cutting and/or trimming of crash bars as they are there for a reason. It is does not have CCD however it does have BlueCruise - which I love and want to retain.
I’d appreciate your advice on this. Here’s a pic of my truck towing two ATV Rhinos on a 20’ steel car hauler recently - it did great.
