33.5" tires rubbing with 2.5" level kit
rad
curt
Jul 18, 2021
courtenay bc
2021 f150
grocery nights
Lift and diameter don’t seem to be your issue since people are running bigger sized without rubbing at all. Even raptor 35 inch tires with the +34 offset raptor wheels fit on these 21s stock without rub. Running a 315 tire may be too wide for the stock f150 wheel with +44 offset and you’ll probably rub on the inside but maybe a 2inch spacer is too aggressive and now you rub against the crash bars when making turns. You’ll probably just need to run a smaller spacer and you should be good to go. Find the balance where it’s just enough to not rub on the inside but not big enough that it pushes the wheel out too much where now you rub on the outside.
it was just rubbing on the mud flap i removed them now good to go
rad
curt
Jul 18, 2021
courtenay bc
2021 f150
grocery nights
was just hard that there's such slim picking for big tires the size i have is not the size i wanted but need ground clearance for off road
