33.5" tires rubbing with 2.5" level kit
rad
curt
Jul 18, 2021
courtenay bc
2021 f150
grocery nights
put a 2.5 level kit in my 2021 f150 and it does not accept 33.5 tires rubs big time
Doyouevenboost
Brian
Mar 17, 2021
196
300
Minnesota
2002 Subaru, 21 f150 502a ecoboost
Utility maintenance worker
Thats interesting considering the stock tire is a 33.. and there are countless guys on here running 34.5’s..
What’s your setup? What tires, Wheels, spacers, 4x4, fx4, max tow?
rad
curt
Jul 18, 2021
courtenay bc
2021 f150
grocery nights
4x4 stock tires are 32.6 inch i put 315 65 18 on with 2 inch spacers max tow 14000 lbs
ScottBB
Scott
Jun 9, 2021
563
604
Mississippi
2021 Ford F150
Did you change rims as well? What is the offset? You not only got taler, you got 2 inches wider. Probably not the height that is causing the rub, it may be the additional width.
Doyouevenboost
Brian
Mar 17, 2021
196
300
Minnesota
Apologies. The stock 20 inch rim comes with 33’s.
Your problem is the spacers not the tires! ?
Tizzzo
Ed
Feb 5, 2021
450
388
California
2021 Lead Foot Gray XLT 5.0 Supercrew 4x4
Veteran
Sounds like an offset issue to me, is this stock wheel or aftermarket wheel?
Zyvin
739
990
SC
2021 F150 Crew, FX4, Lariat
Diameter is not your problem.
rad
curt
Jul 18, 2021
courtenay bc
2021 f150
grocery nights
stock which ive used on my 2010 2013 2017 and 2018 f150
rad
curt
Jul 18, 2021
courtenay bc
2021 f150
grocery nights
315 vs 275 are 1 1/2” wider than stock and you have 2” spacers. Level kit won’t accomplish what your looking for. Have you tried your set up without the spacers?
yep i added the spacers in after i removed the mud flaps now it is just barley clearing so should be ok it was just hard to.find tires as coved has back logged everything
rad
curt
Jul 18, 2021
courtenay bc
2021 f150
grocery nights
they weren't the size of tire i was after but had to settle.for worst case i will.put a lift in you can get a 3 inch lift for 600 bucks
rad
curt
Jul 18, 2021
courtenay bc
2021 f150
grocery nights
2021’s also have a wider track than previous years..
yah just needed talker for clearance for the cross ditches in hunting season cant use mud flaps unfortunate just such limited tired around
Tizzzo
Ed
Feb 5, 2021
450
388
California
Veteran
Lift and diameter don’t seem to be your issue since people are running bigger sized without rubbing at all. Even raptor 35 inch tires with the +34 offset raptor wheels fit on these 21s stock without rub. Running a 315 tire may be too wide for the stock f150 wheel with +44 offset and you’ll probably rub on the inside but maybe a 2inch spacer is too aggressive and now you rub against the crash bars when making turns. You’ll probably just need to run a smaller spacer and you should be good to go. Find the balance where it’s just enough to not rub on the inside but not big enough that it pushes the wheel out too much where now you rub on the outside.
