joeniosi
- Joe
- Oct 22, 2022
- 1
- 13
- 5
- Calgary, Alberta Canada
- 2022 F150 Platinum
Picked up my new 22 F150 Platinum Sept 14th. Noticed within a week one of the LED's on the driver headlight assembly was flickering. Booked into service Oct 11th. Dealer found "loose connection" which was "repaired". Couple days later, notice headlight flicker still present. Then I get restraints indicator lamp warning(airbag light), related to the occupant classification system module fault in Fordpass. Fordpass also notified me of battery low, deep sleep mode several times. Rebook Service Oct 20th. Headlight assembly is ordered, and restraints module is replaced but does not fix problem. Battery has failed and also needed to be replaced. Now power running boards stop working. Return Oct 24th. Headlight assembly replaced, and new part installed for restraints control system(airbag light) installed. Still does not fix problem. Ordered seat cushion sensor - no parts available, and no ETA(special order and must be manufactured). I'm told if Airbag light is on, the airbag system is completely disabled. I have had this truck for 5 weeks, and it's completely undrivable...
