2021 CAW Raptor style LED Amber Grilled Light kit for the Lariat has now been added to the website.
2021 F150 with Lariat Grille Custom Auto Works Raptor Style LED Amber Grille Light Kit 2021 LR
2021 F150 Raptor-Style Grille Light Features:
If you're looking for a subtle and classy lighting upgrade for your 2021 F150 Lariat with an OE-style look, then this Custom Auto Works Raptor SVT-Style Grille Light Kit is perfect for you. This complete lighting package features three amber lights mounted on a bolt-on bracket that gives your "standard" F150 the aggressive looks of an SVT Raptor with absolutely no hassles. All three lights come pre-installed in the heavy-duty bracket, allowing you to bolt this kit on behind your truck's grille, wire the lights in, and get going in only a few minutes. The kit comes standard with a plug-and-play harness for an extremely easy install. Complete Raptor-Style Grille Light Kit
Custom Auto Work's SVT Raptor-Style Grille Light Kit comes with everything you need for a quick and easy install. The bracket that's included with each kit comes with an adjustable slider that allows you to perfectly line up the lights with your truck's stock or aftermarket grille without doing any custom modifications. The lights come with a full wiring harness that hooks into your truck's running lights to give these grille lights power as soon as you turn on the ignition. The lights themselves are completely waterproof and are DOT-Approved for street use. The light kits even comes backed by a 5-year Limited Warranty.
2021 F150 Fitment: this Raptor-Style Grille Light Kit will only fit 2021 F150s with a stock Lariat grilles. This kit will not fit models with XL, STX, XLT, Limited, or Platinum Grilles. A version for XL and XLT Grilles is available here.
- Gives your Lariat Raptor-style grille lights in no time
- Complete bracket with three amber LEDs
- Bolts on to stock grilles without drilling
- Waterproof LED boards
- Easy to use plug-and-play harness
- Backed by a 5-year Limited Warranty
