2021 F150 Starkey Products OEM-Style LED Bed Light Kit 4780
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
2021 F150 STX CrewCab 4x4
For anyone looking to add bed lights to their truck here is a great solution.
Ford F-150 2021 F150 Starkey Products OEM-Style LED Bed Light Kit 4780 1635450418162
F150 Starkey Bed Light Kit Features:
  • Provides clean, OE-style bed lighting
  • Features drop-in LED lights and wiring
  • Extremely easy, drop-in install
  • 6000K color temperature with good output
  • Backed by a Starkey 5-year limited warranty
  • May require additional harness if bed is not pre-wired
  • Will only fit F150s built before July 2021
Excellent Fit, Look, and Bed Lighting Capability for your F150
While some 2021 F150s come standard with LED bed lighting, a lot of submodel and packages did not, which can leave you in a lurch if you're using your bed after dark. Starkey Products has your back with their OE-style LED Bed Lighting Kit for 2021 F150s. The Starkey Kit comes with a pair of OEM-style bed lights and the wiring connectors you need to get them up and running on and F150 that's pre-wired from the factory. The Starkey Bed Light Kit gives you that OE-style functionality in an extremely clean package. The lights feature a bright, white 6000K color temperature and install into the factory bed light provisions and don't require any dealer BCM reprogramming to get them up and running, which saves you some hassles. OE-Style, Waterproof LED Bed Lights with Wiring and Splitter
Each kit features an easy, drop-in install while getting you the bed lighting you need to get the job done. The Starkey Bed Light kit comes with a pair of OE-style bed lights that feature polycarbonate lenses and are IP67 waterproof rated so that hold up in practically any application that you have in mind for your F150. The kit comes with wiring extensions for the bed lights as well as a Y-splitter for hooking into the stock, pre-wired bed harness. Installation is incredibly simple, and does not require any splicing for installation if your truck is pre-wired for bed lighting. Starkey includes all necessary components and detailed instructions, while backing their kit with a 5-year limited warranty.
Fitment: 2021 F150 built before July 2021
Will not fit 2021 F150s built after July 2021: due to a mid-year wiring change by Ford, this bed light kit will only fit 2021 F150s manufactured before July 2021.
Additional harness for un-wired beds: while most 2021 F150s came with their bed pre-wired for bed lighting, some did not. If your F150 is not pre-wired, you will require Starkey's Extension harness from our drop-down menu above. If you're unsure about whether your bed is pre-wired, please see Starkey's Install Instructions here.
motivology
DK
Aug 5, 2022
139
61
2021 Ford F150 Platinum Powerstroke
Realtor / Entrepreneur
Have a picture of it installed? And night shot?
Stage3Motorsports
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
motivology
DK
Aug 5, 2022
139
61
The starkey video should show all that you asked.
I should've clicked the link and check it out before posting. I'll keep this in mind when I do get my '21 F150 truck. Thanks!
Stage3Motorsports
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
No big deal, thats what im here for.
kb2755
Jul 26, 2021
749
714
Ontario, Canada
'22 F-150 XLT 302A Sport
Just watched the video. Advantage to these over the OEM ones - they come on automatically when a door is opened or with the overhead light switch button.
Huge gripe with the OEM ones is that you have to press the button in the bed to turn them on. Super frustrating with a toneau cover installed.
