Another option to look at is one of the parallelable inverters. There's quite a few out there that aren't marketed. Unfortunately to use them requires a darwin cord which can be made safer by a breaker.yes i have a softstarter.
that is an idea i have thought about because i have a strong battery with a strong inverter and i was wondering if there was some way my battery could "help" get the compressor going. but at that point i feel like its just not worth it. ill size up one on the propower if i get another ford.
Consider upgrading your RV inverter so that it can power your AC and other loads. Even better if you find one that will accept a 'grid' input where you can dial in the current it tries to pull.
If you find one, what you'll do is basically keep the truck going at whatever max current it's happy with, when the AC isn't running the compressor, the excess energy goes into the batteries, when it's time for the AC to turn on, power is pulled from the batteries to start it up and if there's additional energy after it's started, that power is diverted to the batteries.
Oh, they make a variant of the 150 called the powerboost, I went that route myself because 7.2kW onboard pure sine inverter
