Stevenbm99
22 lariat sport on 35” ridge grapplers
2.5 Falcon shocks front and rear. I also swapped out rear block for 2in. 295:70/18 with rebel 6 on +20. No trimming and nothing rubs. I’ll get some better pics soon.Can you please provide level, wheels and tire specs?
It look great, thanks.2.5 Falcon shocks front and rear. I also swapped out rear block for 2in. 295:70/18 with rebel 6 on +20. No trimming and nothing rubs. I’ll get some better pics soon.
Thank you sir. My first set up was a simple 2in puck spacer. For some odd reason I was scuffing my coils at full droop with this set up. So I did the shock route and now no scraping or anything. Also I would highly recommend Cooper Discovered AT3 XLT to anyone. I’ve had Nittos and BFG and also Toyo RT and these coopers do everything very well.It look great, thanks.
My plan is bilstein 6112s or fox coilovers. Those tires are on my short list as well. I’ve been spoiled with Falken’s the past 4 years. However, i’d like to buy American tires for my next set.Thank you sir. My first set up was a simple 2in puck spacer. For some odd reason I was scuffing my coils at full droop with this set up. So I did the shock route and now no scraping or anything. Also I would highly recommend Cooper Discovered AT3 XLT to anyone. I’ve had Nittos and BFG and also Toyo RT and these coopers do everything very well.
Very good point. Those Wildpeaks perform excellent and are priced fair compared to others.My plan is bilstein 6112s or fox coilovers. Those tires are on my short list as well. I’ve been spoiled with Falken’s the past 4 years. However, i’d like to buy American tires for my next set.
I was very, very close to ordering an HDPP in Stone Grey instead of the truck I ended up with.Did someone say 157" wheelbase? I _finally_ picked up mine...
What did you use to black out your taillights?2.5 Falcon shocks front and rear. I also swapped out rear block for 2in. 295:70/18 with rebel 6 on +20. No trimming and nothing rubs. I’ll get some better pics soon.
https://www.amazon.com/VHT-SP999-Ni...ocphy=9031174&hvtargid=pla-491180092769&psc=1What did you use to black out your taillights?
Forget the outside; let's see that payload sticker! LolDid someone say 157" wheelbase? I _finally_ picked up mine...
