stonefly
- Paul
- Jun 14, 2022
- 6
- 36
- 23
- California
- 22 Platinum S Crew Powerboost
I've had a long-standing problem with my travel trailer. I've reviewed many of the threads related to gain insight messages "Trailer Wiring Fault" & "Trailer Disconnect". I'm hoping for some insight from anyone who knows more about F-150s than do I (that should cover just about anyone on the forum).
Below is a summary of the phenomenon.
Additionally see screenshot from Forscan Lite indicating Trailer Brake output "short to ground". Cannot seem to find the date of occurrence anywhere, but highly likely AFTER it was evaluated by local dealer.
Notes & Questions | ||
Problem: | Message: "Trailer Wiring Fault" upon connection to trailer | Occurs with 7-pin connection on Travel Trailer. No message when connecting 4-pin connector on boat; |
Light check | All lights functional | |
Depress Brake Gain tabs | Message: "Trailer disconnected" | Message received during each trailer use over 1 year; vehicle light check indicated all functional, BRAKES FUNCTIONAL when towing; Trailer D/C is now constant when BC gain activated. TRAILER BRAKES NON-FUNCTIONAL when driving |
Suggests fault in brake controller function | ||
FUSES Checked | 42 - Trailer Brake Module | # 42 Continuity Functional; NONE of the fuses were fully seated |
Test GND Resistance | Truck power OFF, No Trailer | |
GND - Frame | 0.0 ohms | Just what I'd expect |
GND - 12V | 328 k ohm | Why do I see these resistance values for 4 pins? Should I not expect to see 'O.L' for all? |
GND - BC Output | 81 k ohm | |
GND - R TURN | 76 k ohm | |
GND - L TURN | 76 k ohm | |
GND - Reverse | 'O.L' | |
GND - TAIL/Run | 'O.L' | |
Test Pin Voltage | Truck power ON, No Trailer | |
GND - 12V | 13.3 Volts | |
GND - TAIL/Run | 12.99 Volts | |
GND - R TURN | 100 mV | signals not activated; values expected, no variation in measurment |
GND - L TURN | 100 mV | |
GND - BC Output | 100 - 350 mV | brakes not activated; constant variance within noted range |
Brake Pedal depressed | ||
GND - BC Output | 6.5 Volts | Should I not expect 12 Volts for BOTH? |
Test Pin Voltage | Brake Gain adjustment activated | |
GND - BC Output | 8.5 Volts | |
Other | ||
Pins on truck and trailer and their general fit | Cleaning THOROUGHLY changed nothing; no intermittent connections noted; assessed multiple times over past year | |
Uninstall/Reinstall Trailer Profiles | Ineffective | |
Ford Dealer Assessment | Simulator | all the little lights come on when they are supposed to… |
