fordtruckman2003
Did you reset the APIM and ignition off and on?
I just did and that fixed a lot! Nice. Thanks. Forgot that step. You guys are the best.Did you reset the APIM and ignition off and on?
Edit: OK sorry, I just got back from daughters dance recital, looks like you are good to go. Good group of guys here!That’s exactly what I was thinking. Someone else’s original numbers should be the same as what mine were? If you’d share your values prior to the Unreal theme mod, I’d be forever grateful. As you said…the climate stuff etc would have to come from someone else but I believe they only work with the Unreal theme anyway?
Lesson learned! Thanks again!Now save a GOOD copy of every module before you change anything.
Stuff happens, you'll want that option to go back.
As @Big Dog Daddy mentioned if the update showing on your screen went through it could have uploaded bad asbuilt to Ford servers. Then it's permanent until it gets backed up from truck again.
This is great. Thank you!!Ok what ya need just the APIM Screen?
Here is my snapshot of my screen. Everything APIM related is default except I do have 75th Anniversary enabled.
So the default on that is:
7D0-03-01 xxxx 02xx xx--
Now with THAT said, BACKUP what you currently have in case you make it worse...
Dance recital. Sounds like you had a worse evening than me haha just kidding. Kids are great.Edit: OK sorry, I just got back from daughters dance recital, looks like you are good to go. Good group of guys here!
So, one further step I do, beyond the backup prior to change is I actually mark each code in my Livnitup spreadsheet. Really nice to just go back and do a manual change if needed.
Do you still have unreal engine and climate bar but is oriented right or have you removed those items back to stock?Looks like I’m back to normal. Thank you everyone. You saved my ass. Appreciate you all!
I’m back to stock now and happy for it. I’m sorry, I’m not sure what may happen with yours. I’m very new at this and learning the ropes. Now that I have a solid back up, I’m going to try again, minus the text input. That seems to be where it went off the rails. Will post findings if something abnormal happens. Thanks.Do you still have unreal engine and climate bar but is oriented right or have you removed those items back to stock?
I have unreal engine and climate bar enabled (close to 6 months now), and am on 6.4, should I be concerned that the future updates will create similar issues on my truck?
Thanks in advance.
Thanks for quick reply. Glad you are back to stock with help from this forum. Pretty "unreal" community. Makes you glad u bought a ford!I’m back to stock now and happy for it. I’m sorry, I’m not sure what may happen with yours. I’m very new at this and learning the ropes. Now that I have a solid back up, I’m going to try again, minus the text input. That seems to be where it went off the rails. Will post findings if something abnormal happens. Thanks.
What is the ambient lighting change you did?Thanks for quick reply. Glad you are back to stock with help from this forum. Pretty "unreal" community. Makes you glad u bought a ford!
I don't have text input and no plans to add it. I have backups and have kept record of the changes I've made so far. My changes (unreal, climate, bar including heated heats, Bambi, double honk, DRL brightness and ambient lighting) were made a long time ago so I will wait and see if any update changes things.
I have an XLT and with help of several people on this forum added the lighted cupholder and ambient lighting to front inside footwells. Ie same as lariats (cupholder is from 2021 lariat).What is the ambient lighting change you did?
