was thinking of loading back to original before doing the fdrs updates but have since found out that doesn’t seem to be necessary. I did get 1 ota update back in November which would explain why it won’t load if there’s more or less as built fields.@PFXLT What specifically are you trying to accomplish? If there was an OTA and the IPA was involved you don't want to do it since there's a very good chance that the AsBuilt data has changed. If you're loading Forscan and it's looking at your last saved profile then do not use it. I never save the profiles in Forscan for the very reason I mentioned above.
