Pro Power always showing < 200 watts and Ground Fault
Sergman84
Sergio
Nov 8, 2021
46
46
San Francisco Bay Area
2015 Ford F-150 XLT 3.5 Ecoboost 4x2
Hey all
I’ve noticed my pro power onboard always shows the wattage being less than 200 watts and on. I have never turned it on but it shows like it’s constantly on.
and today when I turned it off and tried to test it by clicking the TEST button, it said it noticed a ground fault.
Should I get this looked at by the dealer? What’s the fix
9,040
16,384
Breath.....
First of all the test, especially the first time you do it, will result exactly as you describe. Arguably that's what the test tests! Although admittedly it is confusing to show a failure message to the customer and NOT expect them to be concerned.
As for the <200 watts.....
That's actually accurate.
If you aren't pulling more than 200watts than it's simply informing you that the ProPower onboard system has less than 200watts draw on it.
If you click on Generator mode, you will see both banks displayed and still there will be less than 200watts being drawn.
Your truck has electrical outlets in the interior that supply power even if you are not in generator mode. I never tested them before to see if that screen shows the wattage draw for non generator mode but I suspect it does?
If you just want to verify everything is working normally, test all your outlets with some electrical device like a drill? It'll all make sense after you play with it.
Congratulations on your wickedly awesome truck
Sapphire
May 20, 2021
209
271
Chicago
2021 F-150 Powerboost Platinum (job 2)
Also worth noting that it will default to on every time you start the engine, to provide power to the outlets in the cab.
imnuts
Mar 1, 2021
1,501
1,568
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
It will show the load even when ProPower/generator mode isn't on. I don't know how much you get in that mode, but I've heard you're limited to 400W. I was at ~250W when I checked it.
minirx7
Ed
May 13, 2021
224
160
Toronto
God i hate that.. i wish there was a way to turn it off.. I hate the fan noise.
imnuts
Mar 1, 2021
1,501
1,568
Dirty Jerz
Facilities Engineer
It only defaults to on for non-Powerboost trucks, and there also isn't a fan noise on Powerboost trucks when it is running (unless a radiator fan kicks on).
