Grafx36510
Part number for the HVAC unit with heated/cooled seats, heated steering wheel, and temps in the dials is: ML3Z-19980-K
Did you enable heated wheel in the hvac module ?Well, I was able to get the button to show up on the screen but it is greyed out and I can't select it. Not sure where to go from here, I've tried everything that was previously stated in this thread as far as I know, I think there's just some sort of difference with the Lightning that I don't know yet.
Yes, at least according to the settings that were provided. Lightnings could be different. I'm hoping that someone will post the forscan data for a lightning that has a heated steering wheel so that I can verify it.Did you enable heated wheel in the hvac module ?
733-01-02 | xxxA | xxxx | xxxx |
Yeah, that's what my HVAC had as default, which I found to be odd since I didn't have a heated wheel before. May just be a difference between the models.Same as ICE
733-01-02 xxxA xxxx xxxx
Or 9 depending on what you have
Where has everyone been grounding there power cable is everyone doing it off the bolts behind the sccm or is there another location close by to run the ground from the sccm?
I can make one I guess.. I dont know it would be a big seller. It is only two wires. one ground the other runs to the BCM. It is probably the easiest harness to make.Could anyone point me in the direction of a ready made harness? Boosted Grey Goose has been out of stock for a while and I can’t muster up the courage to make my own as I feel I’d burn my truck down.
Correct me if I’m wrong: one end will be WPT-404 connector from the SCCM, running 18 gauge wire (power/ground) to the BCM/ground point. WT-1004 is the terminal needed to connect power into the BCM?I can make one I guess.. I dont know it would be a big seller. It is only two wires. one ground the other runs to the BCM. It is probably the easiest harness to make.
Make the ground intercept something near the column -- the other one floating around is poo trying to intercept near the BCM.I can make one I guess.. I dont know it would be a big seller. It is only two wires. one ground the other runs to the BCM. It is probably the easiest harness to make.
