Shane150
First off, the ride is less bouncy but I am still running the standard tires and I am getting 1.5" of lift. Plan to change to LT tires which I think will firm up the ride. I completely went a different route than the instructions which was provided by Eibach. Mainly, I removed the lower control arm form the frame instead of removing the upper control arm from knuckle. I simply didn't want to overextend the driveshaft. For me the rear shocks proved to be a bit difficult as it was a real ***** to compress them! Unlike Fox or Bilstein, Eibach is not strapped and is in full extended form!! Not the most desirable form for a garage worrier! I also replaced camber/caster oem nut with the Eibach one. Today I took the truck for alignment and while I was there, I came across a brand I used to admire.
