check your rear wheels...
mikem
Jun 10, 2021
2021 f150 XLT 5.0
My passenger rear wheel sticks out a bit further than the drivers side...anyone else notice this, quite noticeable after installing mud flaps with wider tires and fuel rims.. i would say maybe a 1/4" or a bit more....
can see it by looking down the truck from front and compare with the running board on each side
Pedaldude
1,371
1,997
Is the bed centered on the truck? Another member had their bed installed nearly a full inch off to one side and you could see where it also didn't line up with the cab.
How are the rear wheels when compared with the front wheels?
Zyvin
684
879
SC
2021 F150 Crew, FX4, Lariat
Yea, Id check the bed alignment. Seems that is the easiest of all things to be off a little.
mikem
Jun 10, 2021
2021 f150 XLT 5.0
I dont think its the bed as its off when compared to the running boards which are not attached to the bed, check your truck if you have wider wheels as I think it makes it more noticeable...
Airspeed00
May 31, 2021
39
30
Toronto, ON
2021 F-150 Lariat Sport 4x4 502 SCREW
Make sure that Fuel sent you the (4) of the same offset rims? They most likely did, but can't hurt to check. Swap the rears to check. If not, maybe time to engage the dealer / Ford
