JBinFla
I've had a 2.0 EcoBoost in an Escape, a 3.5 EcoBoost in an Explorer Sport, and now the 3.5 PowerBoost in the F150. All of these engines have had turbo lag issues. At least that's my guess going from naturally aspirated vehicles the whole give it gas and it goes but in 1-second it goes like you wanted it to. Just a bit sluggish at the initial hit of the throttle. I just assumed this was turbo.
But.
I've driven my brother-in-laws F150 with the 2.7EB, and my wife just got a 2022 Ranger with the 2.3EB. Both of those engines have that "instant" hit low end torque that I miss. Sure my car after 1-second has much more power but initially there's a bit of a lag. This is in Normal mode on my PowerBoost, and in Sport sure things are a bit more lively but from an idle it just doesn't seem to respond and it carries the RPM's higher which the other two engines don't do. They just have a better low end responsiveness. Has anyone else noticed this? Is there something I can do to fix it? I can't believe these two smaller engines (with 2-less cylinders) feel more responsive than this "top of the line" engine.
Also.
The brakes. They are quite touchy. VERY touchy actually. It's clear they're not mechanical as in the traditional hydraulic brakes, they are electric and have a very slight strange, or unnatural, feel to them. Also, if I'm pulling in a parking spot for instance, and I want to creep forward 6" to get closer to the car in front, that is darn near impossible. In a "normal" car I would just let off the brake slightly and it would slowly creep up then stop when I'm ready. This you let off brake slowly nothing happens then electric motor kicks in and it lurches 6"-12". This is unnerving as this truck is long and I need to pull in FULLY to all spaces so I'm not hanging out but I'm afraid to get too close because you can't easily just pull forward 3" or something. There's also some kind of "emergency" logic *I think*. What do I mean? I've hit the brake kinda quickly and the minimal amount I hit it created a very fast reduction in speed (more than what I was expecting) whereas if I'm kinda slow on it the same level of "tap" would slow down more predictably.
I"m not sure if any of this makes sense, but there's some odd-ness in the pedal feel. The lag I noticed in my 2.0EB, 3.5EB and in the 3.5PB but the 2.3EB and 2.7EB did not have it. Has anyone else noticed any of this? Are there any suggestions? Maybe after market tunes? Though I'm hesitant to mess with my (extended) warranty I really would like to eliminate the lag if possible. Thanks
But.
Also.
