Have a few in stock if anyone is interested, message me for forum pricing.
2021-2022 F150 Flowmaster Outlaw Extreme Dump Cat-Back Exhaust Kit 818118
2021-2022 F150 Outlaw Extreme Features:
The stock exhaust on your 2021-2022 F150 of choice is built to be quiet and it shows. For F150 owners looking to make their aggressive truck one of the meanest and rowdiest around, you'll need something a little different. The Flowmaster Outlaw Extreme cat-back exhaust kit for 2021-2022 F150s is one of the loudest, most brutal exhaust systems on the market and provides your F150 with a menacing roar that is sure to catch attention. The Flowmaster Outlaw Extreme Kit features high-flow tubing, an Outlaw Series muffler, and a pre-axle dumped exhaust kit that all work together to product a brutal, deep, and loud exhaust note. The muffler and tailpipe assembly also comes decked out in a black finish to give the Outlaw Extreme Kit a great look and some extra corrosion resistance. The pre-axle dump exit gives your 2021-2022 F150 a clean, tipless look and give you some extra clearance if you want to mount a larger spare tire than stock. Each Outlaw Extreme Kit installs right into place of the stock cat-back, though some trimming will be required for some F150 wheelbase sizes. 409 Stainless Steel System with 3" Diameter Tubing and Pre-Axle Dumped Exit
The Flowmaster Outlaw Extreme Cat-Back was designed from the ground up to produce a brutal sound in a quality package. The Flowmaster Outlaw Extreme kit is built out of 16-gauge, 3" diameter tubing that's all mandrel-bent to ensure smooth exhaust outflow and a great fit on your 2021-2022 F150 build. The entire kit is made out of 409 stainless steel that's resistant to corrosion in most climates and applications, and the black powder coat finish on the muffler and tailpipe assembly further improves corrosion resistance. The Outlaw series muffler features a compact, bullet-style design that only provides a minimal amount of sound damping in exchange for maximizing exhaust flow. The Outlaw Extreme bolts on to your stock mid-pipe and comes with all the hardware and instructions you need to get the kit up and running on your own F150 build. The Outlaw Extreme Cat-Back comes backed by a limited lifetime warranty.
Fitment:
Wheelbase fitment: this cat-back system will fit all F150 wheelbase sizes. However, trimming will be required for F150s with a Regular Cab 8ft bed or a SuperCrew 6.5ft bed.
- Adds a vicious, loud exhaust note to your F150
- Features pre-axle dumped tip
- Uses 3" diameter, 16-gauge tubing
- Made out of 409 stainless steel
- Black finish on muffler and tailpipe
- Comes with hardware and instructions
- Backed by a limited lifetime warranty
- Will not fit PowerBoost or Powerstroke
Fitment:
- 2021-2022 F150 3.5L EcoBoost
- 2021-2022 F150 2.7L EcoBoost
- 2021-2022 F150 5.0L V8
- 2021-2022 F150 3.3L V6
