In stock and ready to ship for anyone in the market for a nice stainless exhaust system.
Message me for forum pricing
Frank
2015-2021 F150 Magnaflow 4" Street-Series Single-Exit Cat-Back Exhaust Kit 19577
Highlights:
The 2015-2021 F150s may be some awesome and powerful trucks, but the factory cat-back system doesn't let you know it. Give your aggressive 2015-2021 F150 build a deep, mean, and aggressive new sound in quality that both you and your truck can depend on. The Magnaflow 4" Street-Series Single-Exit Cat-Back Exhaust Kit is a total replacement for your F150's factory cat-back system that completely changes your F150's exhaust note while changing up your truck's looks thanks to its large-diameter tubing and massive 5" diameter exhaust tip that is sure to turn some heads. Magnaflow's 4" Street-Series Cat-Back for 2015-2021 F150s is made out of high-quality materials and was carefully designed and constructed for a perfect fit on just about any F150 build. Magnaflow includes everything you need for installation, allowing you to drop this kit onto your truck right out of the box, though some wheelbase sizes will require minor amounts of trimming. 409 Stainless Steel Construction with 4" Diameter Tubing, Straight-Through Muffler, and 5" Tip
The Magnaflow 4" Cat-Back is made out of quality stainless steel and comes backed by Magnaflow's legendary dedication to fitment and quality. Each exhaust system is made entirely out of 409 stainless steel that's resistant to corrosion in most climates and applications. The cat-back system deletes your F150's factory resonator assembly and comes with a straight-through muffler that generates a much louder and noticeable exhaust note than stock with only some amount of drone. This version of the Street-Series Kit features 4" diameter tubing that's all precisely CNC mandrel-bent in order to give you a perfect fit on your F150 build. Each kit is topped off with a 5" diameter polished tip that exits in the stock location which gives your F150 a subtle change in looks. Every kit comes with installation hardware and instructions. Magnaflow backs this kit with a limited lifetime warranty.
Fitment: 2015-2021 F150
Will not fit 2021 PowerBoost or 2018-2021 Diesel: this cat-back system will not fit 2021 F150 3.5L PowerBoost or 2018-2021 F150 3.0L PowerStroke models.
Wheelbase fitment: this cat-back kit is designed to fit all 2015-2021 F150 wheelbase options. However, it will require trimming for 126", 141", and 157" wheelbase sizes.
Frank
Highlights:
- Generates a mean, new exhaust note
- Awesome look with big tubing and tip
- 409 stainless steel construction
- 4" diameter tubing and straight-through muffler
- Big 5" polished exhaust tip
- Backed by a limited lifetime warranty
- Will not fit PowerBoost or PowerStroke models
