2015-2022 F150 Ford OEM Bed Divider Kit FL3Z-9900092-A
Highlights:
2015 to 2022 F150s that haul gear around or are put to use out on the job site generally have more cargo management requirements than the average truck, and being able to split the the bed into two zones is all sorts of handy. That's where Ford's OEM Bed Divider comes in. The bed divider was optional factory equipment on the 2015 and 2022 F150s and drops right into your bed in a clean, hassle-free installation that will greatly improve your truck's ability to haul around and organize all of your cargo and gear. The Bed Divider is spring loaded and folds against the sides of the bed when not in use, but stands extremely strong when deployed so that you can use it for just about any application that you have in mind. Each Ford OEM Divider is made out of reinforced plastic and nylon composite that allows it to hold up extremely well and take a beating from whatever you're toting around without letting you down. The Divider is extremely easy to install, and drops right into Ford's BoxLink expandable bed system without modifications.
Highlights:
- Split Bed Into Two Sections
- Spring-Loaded Operation
- Reinforced Plastic and Nylon Composite
- Drop-In Installation Without Modifications
