New Product release and available for immediate shipment!
2015-2022 F150 & 2017-2020 Raptor 4WD Grimm OffRoad Complete Skid Plate Kit (Powdercoated Steel) 10516
F150 & Raptor Grimm Skid Plate Package Features:
Protection for your F150 or Raptor's critical driveline components is absolutely essential if you're going to be tackling tough trails or long-haul overland adventures, but the stock skid plates (if your truck even has them) are woefully inadequate. The Grimm OffRoad Complete Skid Plate Package for 2015-2022 F150s and 2017-2020 Raptors offers up complete protection from tough off-road terrain for your critical powertrain and driveline components so that you can make it home safe without a pricey off-road recovery or tow. This complete F150 and Raptor Skid Plate Kit comes with a two-piece engine skid plate, a transmission skid plate, transfer case skid plate, and a fuel tank skid plate for OEM 36-gallon tanks. These Grimm OffRoad Skid Plates are capable of taking the hits from aggressive off-road driving that would leave you stranded out in the wilderness. All of the Grimm OffRoad F150 and Raptor Skid plates feature a heavy-duty construction and bolt right on to your truck without drilling, cutting, or other permanent modifications.
Extremely Strong 11-Gauge Steel Construction with 2-Stage Powder Coat and Bolt-on Installation
The Grimm OffRoad carefully designed their skid plates for a perfect fit, and they build them strong enough to survive the toughest off-road challenges so that your F150 or Raptor makes it home safe. Each skid plate is made out of 11-gauge, high-strength steel that's laser-cut and CNC formed with highly precise TiG welding that gives them a hassle-free, bolt-on fitment for your F150 or Raptor. All of the skid plates have strategically-placed flanges for additional strength, as well as built-in drain holes that allow water to evacuate the skids aft plowing through puddles or fording streams. The Grimm Offroad skid plates come standard with a 2-stage, semi-gloss black powder coat finish that keeps the skid plates protected from corrosion while letting them blend in with your truck's undercarriage. All of the skid plates are made right here in the USA and come backed by a limited lifetime warranty.
Install Instructions:check out Grimm OffRoad's Install Instructions here!
Fitment:
Will not fit PowerBoost: these skid plates will not fit F150 3.5L PowerBoost hybrids due to differences in their locations of their transmission crossmembers.
Requires removal of factory air dam: the front skid plates will require removal of the front air dam for installation.
Will not fit crossmember lift kits: these skid plates will not fit +4" suspension lift kits with dropped crossmembers.
Engine Skids may not fit with some bumpers: the front engine skid plates may not fit with aftermarket bumpers with their own integrated or bolt-on skid plates.
Fuel tank skid for 36-gallon tank only: the fuel tank skid will only fit OEM 36-gallon fuel tanks. It will not fit OEM 23-gallon tanks or aftermarket fuel tanks.
Fuel tank skid requires FX4-style straps:the fuel tank skid plate will require FX4-style fuel tank straps with studs for the OEM plastic fuel tank shield.
Also available as separate pieces
2015-2022 F150 & 2017-2020 Raptor Grimm OffRoad Engine Skid Plates (Powder Coated Steel) 10154
2015-2022 F150 & 2017-2020 Raptor Grimm OffRoad Transmission Skid Plates (Powder Coated Steel) 10155
2015-2022 F150 & 2017-2020 Raptor Grimm OffRoad Transfer Case Skid Plates (Powder Coated Steel) 10156
2015-2022 F150 & 2017-2020 Raptor Grimm OffRoad 36-Gallon Fuel Tank Skid Plate (Powder Coated Steel) 10157
__________________
Frank @ Stage 3 Motorsports - PHX, AZ
Contact me for Forum discounts and Package pricing.
2017-20 F150 Raptor Parts
11-14 F150 EcoBoost Parts
- Provides total underside protection for your F150 or Raptor
- Complete set of bolt-on, drop-in skid plates
- Comes with engine, transmission, transfer case, and fuel tank skids
- Durable 11-gauge steel construction
- Laser-cut, CNC formed, and TiG welded for a great fit
- 2-Stage semi-gloss black powder coat finish
- Made in the USA
- Limited lifetime warranty
- Will not fit PowerBoost
- Only fits OEM 36-gallon fuel tanks
Fitment:
- 2015-2022 F150 4WD
- 2017-2020 Raptor
__________________
