Rah150
Happened to me today. 23 PB. Pulled out 91 fuse looked fine put it back in. Error and fast turn signal went away. Also pushed in a lot of the fuses which did seem not fully set.
I had the exact same problem and the #91 fuse was blown. Changed and all good. My boat trailer is put into salt water a few times a year. One of my clearance lights corroded internally and shorted to ground. Trailer rewire is now on my list.I had this happen last week after hooking my old trailer up.
fast blink. Module fault warning on start. Also had no out put to trailer lights after it started.
i pulled the fuses i saw that said tow.
i kept updating this thread for new info.
Unplugged battery this morning.
everything still has power with the hybrid ??
Then i noticed the fuses at the top of thread.
i hadn’t seen #91 fuse.
i pulled it and it was blown.
i put a 20amp fuse from the aux port in there and all is back to normal.
I’m so glad. So i registered to let y’all know.
