yes we have transmissions temps on the ipcDo we even have a menu that shows trans temp volts anywhere without turning them on with FORScan?
I’ve been looking for the digital readout on trans temp. How do I find it?yes we have transmissions temps on the ipc
but no volts or real oil pressure or temp, which be-fuddles me as my 21 f250 had oil temp etc in a menu screen under TRUCK info
in forscan you can set up a computer in passenger seat...and live stream everything and guess what..oil temp is in there.
i imagine it wont be long that we can access this stuff, especially since the ipma update has the super duty towing info so we get the trailer view in the big screen with turn signals etc
enable it in forscan using the guide that livingitup has on his thread about forscanI’ve been looking for the digital readout on trans temp. How do I find it?
Enable digital temps for engine & transmission on 12" digital cluster only | IPC | 720-07-01 | xxxx | x**x | xx-- | E5 (turbo & trailer brake controller), 65 (turbo & no TBC), A5 (non-turbo & TBC), 25 (non-turbo & no TBC) |
