Good morning. Can you please send over a message with your VIN and the name/location of your local Ford dealer? I would like to look into your oil pressure concerns on my end.My 2023 with the 3.5 and 1875 miles suddenly set a warning of low oil pressure yesterday. I had been running around town all morning then stopped for lunch. When I started up after lunch I got the oil pressure warning, and it also turned the check engine light on. I killed the motor and looked under the vehicle. No leaks. Started back up and and looked good for a few seconds, gauge and info screen, then it lit up again. Called dealership and after talking to the service writer made the drove it to the dealership, No bad noises or high temps, ran fine other than it had reduced power. Hope to find out Monday what the issue is. Has anyone here had a similar issue?
