CBGray
- Chad
- Apr 2, 2021
- 1
- 101
- 73
- Washington
- '21 Lariat 2.7L EB Screw 4x4 501A
- Software
Yep, I definitely have a delay, and it can be easily observed. I'd say it's less than a second - probably about spot on to your 1/2 second observation on your 2022.I'm curious if you experience a slight delay in the door unlocking when you position your hand around the handle. If I walk straight up to my 22 Powerboost and pull the handle, it will still be locked. I have to let my hand sit behind the handle for just half a second and then it unlocks. I was fine with it until I drove a 21 Excursion over the weekend which had the same feature but operated very quickly. There was pretty much no way I could pull the handle fast enough to catch it still locked on the Excursion. I know there is some stuff stripped off the 22's that 21's had due to the chip shortage...wondering if there was some change in proximity sensor from 21 to 22 that caused the degraded performance.
